Simonmtl avatar image
what is the rebulk voltage on the newest firmware for the BlueSolar 100/20
hello,
i would like to know what is the voltage set in the firmware for the BlueSolar MPPT 100/20
MPPT - Solar Charge ControllerHelp
Simonmtl answered ·
thanks you so much for all the information and the quick replies :)
I made a mistake, I have the smart MPPT with the bluetooth connectivity.
My FW is v1.39, so I went for some reading on the professional portal. very instructive. I will be waiting for the new FW update
1 comment Share
No worries.
The latest information is that v1.42 is due to be released next week, providing everything goes well.
See update in https://community.victronenergy.com/questions/8178/why-doesnt-the-documentation-warn-that-multiple-mp.html
But you will probably need to wait a bit longer for VictronConnect to be updated with the functionality to manually configure the re-bulk voltage/offset.
Mark avatar image
Mark answered ·
In your earlier post you did not confirm the firmware version that you are running on your MPPT - as the re-bulk voltage has recently changed & v1.40/v1.41 FW were cancelled quickly after release, you really need to check/confirm this first using VictronConnect.
Since you have a BlueSolar charger it would not have inbuilt Bluetooth & you will need to either use a VE.Direct Bluetooth dongle OR a VE.Direct to USB cable to access VictronConnect.
To confirm the FW revision go into 'Settings' then click on the 3 dots in the upper right corner;
Then the FW version will be displayed in the 'Product Info' window that appears;
If you want to see the changes for each FW revision you access this by creating a Victron Professional account (https://professional.victronenergy.com/) and download the MPPT firmware change log.
In the latest change log, for FW v1.41 (that was cancelled), under 'Charge algorithm improvements' it states;
So this implies that the re-bulk voltage on FW v1.39 & earlier is 13.7v and the default re-bulk voltage for FW v1.40/1.41 was changed to 13.4v.
Also, under 'Known issues' for FW v1.41 it states;
(which sounds like the issue you were having)
But now after reading this again - I'm not so sure that the 're-bulk' voltage really was 13.7v before, it seems very high, even if float is set to 13.8v. So maybe @mvader (Victron Energy Staff) should confirm 100% that this is not a typo.
In the upcoming FW revisions it is still expected that the re-bulk voltage will become user configurable, as was intended in v1.40/1.41 (but possibly as a delta to float voltage) rather than an absolute number.
So if you can hold out for a little while the default re-bulk voltage should not be a concern...
Share
