V3.00 on Venus GX, has been working, now not responding/working. Have gone back to standard v3 firmware and back to large, no change. Any suggestions.
Followup. Upgrade to 3.10, still doesn't work anymore
Hey, to find out what the issue is, I see no other option then for you to login on ssh of your GX device, and have a look at the Signal K Server logs.
See this doc for more info: https://www.victronenergy.com/live/ccgx:root_access
Note that there is also a Slack group for Signal K; where there will be more knowledge about its plugins and, once you have the logs, how to solve issues.
The alternative solution is a more blunt one: reset the GX to defaults which will automatically also wipe all signalk config.
I’m sure it will start once the config is fresh.
46 People are following this question.
