jim-henault avatar image
jim-henault asked
Signal K - Error: remote installation does not seem to have a running Signal K service.
I had SignalK up and running great on a Cerbo GX for weeks but yesterday when I tried to start SignalK I received the following message - Error: remote installation does not seem to have a running Signal K service... Tried a Cerbo reboot and uninstalling/reinstalling Venus OS Large but the issue remains... Appreciate any suggestions on how to resolve the issue...Thanks!
Venus GX - VGXSignalK
@Jim Henault
Have you checked Settings > Venus OS Large features to see if Signal K is enabled?
jim-henault avatar image jim-henault commented ·
Thanks! I have... Even disabled it and then re-enabled it a couple of times.
Stefanie (Victron Energy Staff) avatar image Stefanie (Victron Energy Staff) ♦♦ jim-henault commented ·
Do you have ssh access to the GX device?
If yes, then do a svstat /service/* and check if signalk-server is running.
Example output:
/service/signalk-server: up (pid 1613) 2718223 seconds, normally down
If no, then do a
svc -u /service/signalk-server
to start the Signal K server and see if it solves the problem.
jim-henault answered ·
Thanks for the recommendation! Verified via ssh that the signal-k server is running but I'm still getting the Error: remote installation does not seem to have a running Signal K service... Time to reload the firmware via usb?
alnavasa avatar image
alnavasa answered ·
I am having the same issue, I even tried to install normal image and the the large image (all remotely) and I am with issues, I am now locally and can't access signal k either
Joel Nordahl avatar image
Joel Nordahl answered ·
Where there any solutions to this problem. I'm having the same now on a fresh install. Was working and used it for a bit then after a reboot it won't start.
Log file has an error in it.
*** starting signalk-server ***
*** Starting signalk ***
internal/validators.js:124
throw new ERR_INVALID_ARG_TYPE(name, 'string', value);
TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received undefined
at validateString (internal/validators.js:124:11)
at Object.join (path.js:1148:7)
at xdg (/usr/lib/node_modules/signalk-server/node_modules/application-config-path/index.js:13:15)
at applicationConfigPath (/usr/lib/node_modules/signalk-server/node_modules/application-config-path/index.js:33:26)
at Object.<anonymous> (/usr/lib/node_modules/signalk-server/node_modules/devcert/dist/constants.js:17:21)
at Module._compile (internal/modules/cjs/loader.js:1072:14)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
at Module.load (internal/modules/cjs/loader.js:937:32)
at Function.Module._load (internal/modules/cjs/loader.js:778:12)
at Module.require (internal/modules/cjs/loader.js:961:19) {
code: 'ERR_INVALID_ARG_TYPE'
Is there a solution to this? I looks like signalK is trying to start over and over.
Could it be a node.js problem?
Best regards,
Joel
alnavasa answered ·
dahlei avatar image
dahlei answered ·
I ran out of space in my /data folder, and now i have this issue.
Deleted some files, but server will not run.
I have tried updating large and normal image, enabling/disabeling signalk and node red. Nothing helps. I now have 200 MB of free space in my /data folder.
dahlei avatar image
dahlei answered ·
Deleted all the .log files in signalk. Now everything is working again:
Venus GX manual
Venus GX product page
