joeblack avatar image
VRM Dashboard and energymeters issues with Raspberry Pi
for nearly one year i am using Raspberry pi with Venus os (latest v2.31) and two energy meters. I noticed that recently several dashboard improvements were released. Unfortunately since June 16 dashboard does not longer shows the data. Strange is that Remote console or Advanced page works perfectly fine and i can access all data. In past this issue occurred but reboot always fixed that, no chance now. Any ideas ?
Br
Martin
yellow shows 1f meter, red is 3f +1f together so do not be confused
VRMRaspberry Pi
Dear Teun,
indeed you are right. I compared this raspberry device is working fine (it has right time)
and this one not. Do you know how to set it correctly? I assumed so far it is synchronizing the time automatically ?
Br Martin
1 comment Share
Sometimes time synchronisation is not available (it relies on ntp, so if that for some reason is not available it cannot synchronise). Might be easiest to just set it manually for this device.
Teun Lassche (Victron Energy Staff) avatar image
Hi @joeblack, this can be caused by a wrong configured timezone in (under Settings > Date & Time on the remote console)
Share
