yawnbox avatar image
yawnbox asked
Off-grid split-phase AC and ground
(there should be an image link at the bottom of this post allows you to zoom in and see the full picture, or you can right-click the image and "open in a new tab")
Hello-
This is a rough draft of a 48V off-grid steel-hull sailboat design. I'm unsure about grounding for my setup. The Victron MultiPlus-II manual is unsatisfactory at adequately describing off-grid chassis-earth ground.
Do I-
1. (as the diagram shows) take the two green/ground wires from the two MultiPlus-IIs and screw them to an AC load panel ground bar, then wire the ground bar to the common chassis-earth ground shared with the DC loads?
or
2. take the two green/ground wires from the two MultiPlus-IIs and screw them to an AC load panel ground bar, and that's it?
Also-
Given my lack of experience in these things; overall, does the AC design need any modifications?
Thank you
Multiplus-IIGroundingsplit phase
yawnbox answered ·
What am I supposed to do if not even the company that sells me this stuff will help?
ejrossouw avatar image ejrossouw commented ·
Victron only offers support through their dealers/distributors and I am sure your dealer will be happy to assist. Maybe worth engaging a suitably qualified person to ensure you don't overlook anything.
yawnbox answered ·
Still waiting for the company who sold me this stuff to answer a question about their products.
