I have a Tesla and would like to use the cig socket to charge my RV battery. The socket gives 15.5 volts and 12 amps continuous output. Is there a Victron product that I could use in the scenario?
An Orion DC:DC charger could be used. If the Tesla socket is continuously rated.
Cig sockets in cars are typically rated for 10A max; your Tesla cig socket is rated at 12 A; the wiring will be flimsy accordingly.
To answer your question : yes, it will probably work, but you are at the very limit .... Why don´t you change the cig socket into something a little bit more solid, like e.g.an Anderson PP30 or PP45 with thicker wire accordingly - would make me feel a lot more comfy, if I were you !
44 People are following this question.
