VRM is showing between 250-500w feeding into static generator? Just had some heavy storms, could this be causing some leakage via the generator?
Slightly concerning as the input relays should be open if there is no AC present at the input.
You would need to check if they are open or not.
What is the LOM set to?
49 People are following this question.
