bazorp avatar image
bazorp asked
VE Bus V2 Bms in victron connect
Can anyone confirm if the VEBus BMS V2 should be shown in any way on the Victron Connect app. On the remote dashboard once logged on to VRM if you select firmware update it only sees the multiplus 2 1600. In the BMS manual it clearly states that the BMS is updateable both locally and via VRM but I just can't find it shown or mentioned anywhere even if i plus the vebus mk3 dongle directly in to it..
For clarity the vebus RJ45 socket on the BMS is connected to the inverter on the multiplus socket and the socket for remote panel is plugged into the cerbo. On the Cerbo the other vebus is connected to the remote panel, the second plug on the inverter is empty.
Is this correct? The system seems to work and can be remotely switched via the remote panel.
Any help/ information is greatly appreciated
Kind regards
Barry
vrm firmware update
bazorp avatar image bazorp commented ·
Managed to update both the multi and the bms, thanks for the help
pwfarnell avatar image
pwfarnell answered ·
The VE bus BMS V2 is listed in Victron Professional so there is an expectation that it can be updated. You can get a free account on Victron Professional and then access firmware and changelogs. I can not help further as I do not have one of these, I have just been looking at one.
https://professional.victronenergy.com/
https://professional.victronenergy.com/downloads/firmware/
https://professional.victronenergy.com/downloads/firmware/file-download/?name=VE.Bus%20BMS%20V2/VE.Bus%20BMS%20V2%20-%20changelog.docx
The Changelog states
VE.Bus BMS V2 changelog
How to update?
Update using VictronConnect or VeFlash. These program is available for download on https://www.victronenergy.com/software/.
Update using VRM under Device list -> Firmware-update
What version do I have?
Firmware version is visible in VictronConnect in the product info screen of the Multi/Quattro
Firmware version is visible in VRM under Device list -> Firmware-update
Venus console -> Multi/Quattro -> Device menu
The latest firmware is listed as V113.
Thanks for the help
bazorp avatar image
bazorp answered ·
Issue is now resolved, thanks for the help.
Kind regards
Barry
