4senergy avatar image
4senergy asked
PV input voltage in Charge controller is 0 volt.
I installed 4 victron charge controllers 250/100, 2 quattros and 3 lithium ion phosphate battery 10.3 kWh.
--> while the CC were charging the batteries I flip up the 250 A DC breaker of the inverter, the discharged capacitors inside the inverter causes the battery to switch off and than switch on. This also causes the controllers to stop producing, after a while two charge controllers start producing and the other two still not producing.
With a multitester, I check the pv output voltage when the CC PV breaker is off, voltage is 202.
And than when the breaker is on, the voltage reading is 0 volts.
MPPT Controllers
tnt369 avatar image
tnt369 answered ·
disconnect the MPPT from PV and Battery. Wait for some minutes and than reconnect battery first. after some minutes reconnect the PV and check if it works now.
tnt369 avatar image
tnt369 answered ·
Always start the Quattros with a resistor in the DC-supply first to charge the capacitors inside. the inrush current is quite high for the batterys. So its better to limit it with a resistor (i.e. 10 Ohm). After a few seconds of "charging" its fine and you can connect the batteries (by breaker).
MultiPlus 12/3000/120-50 120V inrush current on initial startup - Victron Community (victronenergy.com)
Inrush current Quattro 230V 48/10000VA for BMS dimensioning - Victron Community (victronenergy.com)
Pre-Charge Issues - Victron Community (victronenergy.com)
