dbollardini avatar image
dbollardini asked
Multiplus 2 parallel - Grid Charge current not lower than 7.5A
I'm using 2 x Multiplus II 3000/24 in parallel and all works fine. I use it on a big RV Car.
When i try to reduce grid current limit for old campgrounds the lowest limit is 7.5A / 230V.
( I remember it was a limit of 3.5 Ampere when standalone )
Is there a way to have a lower input current from grid ?
Only 1 Grid Input wire doesn't work. Multiplus goes to error when different inputs.
Many thanks for every idea
Dino
multiplus in parallel
derrick thomas avatar image
derrick thomas answered ·
If you disable power assist you can set the input current limit lower. Only other option is to shut one of the multis off and reconfigure for stand alone.
