wreyford avatar image
wreyford asked
BlueSolar MPPT 150/70 stops supplying loads once Float of batteries finished
My problem, is that the MPPT after Bulk, Goes into 'Float' for 2hours, and then stops supplying the loads, and the batteries then start to discharge. This happens between 13:00 and 14:00, with ample sun, so this then drains my batteries unnecessarily.
I tried so many settings but cannot get it to supply the loads, while there is sunlight.
Totally off grid on a farm.
My setup is as follows:
Old Blue Solar MPPT 150/70
Old Firmware (Not upgradable) Multiplus 24/3000/70-50
- Firmware 209
BMV 712 Smart
Color Control GX
Hubble AM-4 Lithium Battery X 2
Hubble CloudLink (RiotCloudLink)
As you can see from the above images, as soon as float is finished, it just stops supplying, and the battery is drained.
The Charge Setting on the MPPT (Menu 04) is Set to 7 for standard Lithium presets.
The Color Control GX is setup to DVCC.
The Multiplus does not work with DVCC, as its too old to upgrade, but this should not influence the MPPT though.
I hope that I have supplied enough info, and am hopeful for a solution.
MPPT ControllersLithium BatteryCCGX Color Control
klim8skeptic avatar image
klim8skeptic answered ·
@wreyford you cannot use the older VE Can mppt with DVCC.
As a test disconnect the VE Can cable Between the CCGX and mppts.
Dont forget the terminators.
Set up your rebulk off set to 0.1v it will start the process sooner.
