andy156 avatar image
andy156 asked
What happens on a load over 50A on AC Out 2
I have a Quattro 10000. I am trying to manage the loads on the AC Out 2. I have a heat pump and car charger. I'd like to occasionally ramp up the immersion on the heat pump to 30A but the car charger runs at 32A. So using 30A without the car plugged in is fine, but if someone plugged in the car and it ramped up to 32A then that is obviously overload. My code can only detect the state of the car being plugged in once every minute.
If my code messed up, does the quattro close the relay for AC Out 2 the instant it goes over 50A? How would I reset it if it does happen?
Thanks
