I have a Victron Energy SmartSolar MPPT 75/10 connected to a Schaudt EBL99 in a Pössl Van
The Schaudt charges only the 2. Battery
Can I connect my Engine Battery to the Lastausgang of my Smart Solar Regulator to charge?
Thank you
The Lastausgang (Load Output) is not for battery charging. Its output Voltage will be the same as that of the battery connected to the Battery terminals.
If you connect a battery to the Load Output terminals it may suffer from over or under charging and will most likely fail early.
7 People are following this question.
