stevew avatar image
stevew asked
VE.Bus BMS and standard 15amp 115 volt receptacle
Greetings from Southern California !!
A hair-brained idea:
Has anyone considered - or perhaps even designed the circuit - to use the high/low signals from the VE.Bus BMS to trigger a relay to energize / de-energize a standard 115 volt receptacle??
I’m thinking of such a device to control a non-victron battery charger / converter. Mostly just to de-energize the device if the BMS is unhappy with an individual cell.
Thanks !!
SW
battery chargingBMS
mvas avatar image
mvas answered ·
Yes, with the correct relay, you can control the 120 volts from an AC outlet.
