nielmalanhuis avatar image
nielmalanhuis asked
Force battery to recharge from grid via Remote Panel or VRM app
I have a grid tied system (Multipluss II, CerboGX, SmartSolar MPPT regulating 4 x 450 W PVs and Pylontech US3000C batteries), that is running with Virtual Switch enabled and Grid Ignore while SOC is > 62 % and load is < 2 KW. All items are inter-connected. There are times when it is required to force the system to recharge the batteries to Bulk manually (i.e. not wait for a battery or load condition). This is due to being connected to an unreliable grid which can shut down at any time for extended periods. Question: Is it possible to force a re-charge from grid session via the Remote Console or the VRM app?
battery charging
With the ESS assistant it would be easy.
You can switch the system to "keep batteries charged" or program a schedule for daily/weekly charging.
Maybe you can use the "general flag" and some "programmable relay" assistants (+ a switch or a relay of the cerbo) to do that but that will need some testing.
nielmalanhuis avatar image nielmalanhuis commented ·
We can not use ESS at all due to the pre-paid meter locking out when even the smallest amount of energy is fed back into the grid, for example this happens when switching off heavy loads. This is a very common request from many users in my area. Please consider adding this feature if possible.
