Alexis Kalogerakis avatar image
Alexis Kalogerakis asked
Quattros frequency shifting
Good evening team.
I have a problem with Ac coupling system in Greece.
3 X quattro 48/10000 (502 firmware, cerbo 2.94 firmware)
Fronius symo 20.0-3 (latest firmware)
Two problems.
1) We have an assistant to ignore AC input.
When we reach the VDC treaty and we ignore input, quattros are stuck and shift the frequency every 20 seconds. 49.9hz, 50.1hz, 53.1hz and Fronius stayed off with 105 error.
To solve this we need to restart quattros.
2) We ignore input and Fronius charges the batteries, when the batteries are full quattros shift the frequency to 53.1hz and keep it there(Fronius is shut down with 105 error) even if we discharge the batteries and VDC is at 50v.
Any suggestion?
Best regards,
Kalogerakis Alexis
AC PV Couplingquattro 10kva
Paul B avatar image
Paul B answered ·
What assistants are being used and are they installed on all 3 units
you do also need a PV assistant or ess assistant
Alexis Kalogerakis avatar image Alexis Kalogerakis commented ·
Hello @Paul B, general flag and 2X program relay to ignore AC, PV inverter support for AC coupling.
Phil Gavin avatar image
Phil Gavin answered ·
I take it this is an off-grid installation.
I haven't tested what I will explain, but I think it may work.
One method to reset the AC coupling is to put a 50Hz supply onto the Quattros.
I think it is sufficient that only the master Quattro gets the 50Hz signal. The Quattros then reset from the 53Hz, back to 50 Hz in order to synchronize to the grid. Resetting the AC-coupling as a consequence.
I think a tiny 1ph 200W-ish off-grid inverter feeding 50Hz onto the Quattro AC input via a contact will do the trick. You can control the contact with whatever, manually, a 30 min timer, a SOC contact etc. that's just a detail.
Paul B avatar image
Paul B answered ·
although my setup is single phase this is my assistant setup, may help and then may not. good luck
also look at the order you have the assistants in as some assistants have to be the very first in the list, this is specified in there descriptions if its applicable.
Also my system is 99.9% always having ac1 in ignored so its always basically off grid.
HOWEVER
I have also placed a isolation contractor in the PV inverters output line, and I then use the generator auto start to turn this relay off when voltage reaches 56v and back on when it reaches lower than 55.0v for 10 min- this was done a long time ago when frequency shifting was not fast enough and I had battery overvoltages on maybe the bank was two small ( ie 12kw), so you maybe able to do something like this to get over the issue.
its a work around if nothing else works the voltages mentioned are examples only
Alexis Kalogerakis answered ·
Hello, my big problem is on the following video.
After input ignored the frequency keep shifting!!!!
@Daniël Boekel (Victron Energy Staff) ?
@mvader (Victron Energy) ?
any suggestions?
Config:
https://we.tl/t-ioc3xFOBJY
Video:
https://we.tl/t-RP1A3cNjpE
Paul B avatar image Paul B commented ·
I see from your setup that you have selected that you cant export.
Your video shows the hz rising and then falling back to 50hz
so how about some graphs that show the battery voltage and the Hz over the period that you are having issues with.
Also how is the batteries BMS connected to the systems and have you also got a shunt or are you using the quattros as the battery monitor.
I am confused.
I interpret your problem as the high-frequency locking out of your AC-coupled inverters so that when you need them, they are unavailable. In other words, there is too much hysteresis before they reset.
The AC-coupled inverter does this once the batteries are charged and there is no alternative route for the power. This is the correct inverter response, but perhaps it can be reset sooner.
I'd like you to reframe your problem with the inverter's response, as I do not understand what you are trying to say is the issue.
Update:
Second system(multiplus 24/5000) with same issue!!
Some screenshots from VRM.
Multiplus 24/5000 (firmware 481, CC Gx 3.00):
Frequency stuck at 53hz all-day and night and system need restart to operate normal again.
Quattro 48/10000 (firmware 502, Cerbo 3.00):
Quattros still frequency shifting after grid charge battery and then ignored.
Need to disconnect grid and some times to restart to fix it.
Any idea to solve the problem please?
Thank you
4 comments
Hi @Alexis Kalogerakis
I'm on holiday so just an idea:
what is your charge voltage set at in ve.configure? this value also influences the pv inverter assistant (what kind of batteries do you use? CANbus?)
Alexis Kalogerakis avatar image Alexis Kalogerakis Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
Good morning @Daniël Boekel (Victron Energy Staff) .
We have opzv batteries.
Absorption voltage 57.6 in ve configure.
55.2 float.
I set CVL at dvcc 57.6 after the problem, but still the same issue.
I remember the rebulk problem with BYD but this is not the same.
When we disconnect grid the frequency keep shifting 49.9-50.1-53hz.
ponzoa avatar image ponzoa Alexis Kalogerakis commented ·
Unlikely relevant but;
Did you activate MODBUS TCP in both the Cerbo GX and also the Fronius? You'd need to make sure they are on the same network (wifi/Ethernet). Perhaps there is a communications issue.
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ Alexis Kalogerakis commented ·
Ah...with grid disconnected but available, it will disable the PV inverter by shortly going to 53Hz, so it can sync with grid as soon as grid is within spec.
I'm not sure how to prevent this. Maybe when instead of ignoring AC input, set inverter to 'invert' instead of 'on'?
