Hi, I need to set up the Generator settings on my EasySolar - II, when i when to turn on the Setting s the Relay menu is missing, please see Picture. Does any one know how to fix it ?? Firmware version 3.00 42
][1]
][1]
Thanks for answering. There is nothing in the Multiplus -II device menu for programing a relay? also when you try and activate the tank pump it tells me to go to Relay settings and set function to Tank Pump the Relay Settings path does not exist.
The only way I have found for the generator is to use the Virtual Switch using VE Config. ( waiting on test results to see if it worked)
There should be another way.? I find it crazy to only the VE config option which is too advanced for most people to even set up and maintain.
34 People are following this question.
