gianluca avatar image
gianluca asked
Multiplus II 48/5000 and Pylontech US5000 cells unbalanced
Dear sirs,
I am writing to report a problem with the US5000 series batteries in combination with Multiplus II 48/5000.
System installation details are as follows:
N. 1 Victron inverter model: Multiplus II 48 V 5000 VA
No. 1 MPPT Victron model: Smart Solar MPPT RS 450/100
N.2 Batteries Pylontech model: US5000
We had the following problems starting from 25.04.2023:
- during the day N. 5 inverter shutdown vith interruption of VAC OUT with no apparent reason (see state OFF of VE Bus)
- at 19:40 the inverter signals "LOW BATTERIES" but the SOC was 97% and the Maximum and minimum cell Voltage was 3,32 V
- from this moment untill 08.05.23 we have no longer shut down of the inverter but from the following day (27.04.2023) we have noticed an imbalance in the cells:
Maximum cell voltage 3.51V
Minimum cell voltage 3.35V
and SOC did not rise above 97% while before was reaching 100%
Starting from 08.05.2023 we have again many other shutdown of the inverter with VAC out interruption:
From the 08.05.2023 one of the batteries, when the system is full charged, did not light up the last green led while the other batterie have all the green leds on
The interpelled Victron distributor told me that's a Battery problem, the battery distributor tell me that there is an issue between all the Multiplus II and Pylontech US5000 and is reccomending not to use the US5000 but only the US3000C with Multipluss...
So as per evidence we are in the middle, somebody can help us?
Multiplus-IIPylontech
ponzoa avatar image
ponzoa answered ·
It sounds similar top a problem I had with US3000C batteries. I solved it updating the battery firmware and imagine this is what will need to be done by th ePylotech distributor.
gianluca answered ·
Thank you for the information, has you done the firmware update by yourself or the distributor has done for you?
How can I handle, do you have acces to firmware updates, software and connection cables for the batteries?
6 comments
ponzoa avatar image ponzoa commented ·
I don't have it for the US5000, only the 3000C which can be found here. The cable and software used to update it is the same
https://drive.google.com/drive/folders/1TCyrFXALgZdh50h9w0IbLDzBCqKaM3te?usp=share_link
I don't have firmware for the US5000, only the 3000C which can be found here. The cable and software used to update it is the same
gianluca avatar image gianluca ponzoa commented ·
Thank you for the support
I’m trying to contact pylontech support but no answer from 10 days. Do you have other channels to get support on their batteries?
ponzoa avatar image ponzoa gianluca commented ·
Your distributor should do this so please contact them.
dayandnight avatar image dayandnight ponzoa commented ·
Hello!
I agree totally with @ponzoa ! That's the job of the pylontech dealer. In case something wents wrong during update you will left alone with a non functional pylontech unit.
Anyway the first and most important task,before updating will be to set both batteries to same SOC level. I use for "pre"-balancing always an external power supply/battery charger like this one.
I didn't do it, but I think the suggestion of @sharpener "Possibly running ESS in Keep Batteries Charged mode for a few days will allow/force the cells to re-balance and that might fix it." will work, too.
I suggest additional to get the right interface cable and battery view software to check manually real SOC level.
Wish you success! Keep fingers crossed!
Servus - DayAndNight
nickdb avatar image
nickdb answered ·
Couple of things, have you ever left a mk3 usb device connected to the system while still connected to a GX? This can't be done, the mk3 must be removed for the system to work properly.
Also, not getting to a 100% is well documented behaviour, it is in the config document and will resolve as batteries balance.
Pylon have a process to make sure all batteries are balanced before using them - it is in their installation document.
Mixing new/newer packs with different levels of charge will also cause this.
All things easily rectified by following all the documentation.
gianluca avatar image gianluca commented ·
The mk3 usb has been removed after installation, the system has been working without any problem for more than 2 months after the installation, reaching gradually the 100% until the 26.04 when the first shutdown series happened
The 2 Pylontech batteries where new
sharpener avatar image
sharpener answered ·
<Maximum cell voltage 3.51V
Minimum cell voltage 3.35V>
The difference of 160mV strikes me as quite a lot. With 2 Pylon Force-L2 modules which are similar technology I saw a maximum of 20mV, and after I added another module it is 30mV.
So as the system was working OK previously I wonder if you have a defective cell. If you use Remote Console to look at the State of Health what does it say (mine is 98% after 1 year)?
4 comments
Hi, I isolate the unbalanced battery, connected alone to the system keeping batteries charged from remote console and limiting the maximum charging current to 1 A. The battery is in this condition from 15 hours and the difference on the cells remain the same and the SOC doesn’t move from 89%img-8516.png
The state of health is 100%
If you have any suggestion..
Thank you
Guy Stewart (Victron Community Manager) avatar image Guy Stewart (Victron Community Manager) ♦♦ gianluca commented ·
Hi @Gianluca,
1A will not be enough to balance the battery, try for 10A, and if that is too much and causes problems, then try for 5A.
Regards, Guy
gianluca avatar image gianluca Guy Stewart (Victron Community Manager) ♦♦ commented ·
Hi, I set the maximum charge current to 10 A, in 3 days i got the lower cell rising of 20 mV.. Maybe in 15 days I will have the cells balanced?
In VRM the status of battery is continuosly bouncing from charging to idle and dischargin, loock like that when the highest cell reach the maximum voltage the system try to discharge to decrease the tension and then try to charge again maintaining this loop
Regards,
Gianluca
daza avatar image
daza answered ·
Are you on the grid? If so Run the inverter in charge mode for a couple of days in order to rebalance the batteries.
Yea I’m on grid, and the battery is on “keep battery charged” from yesterday, I wil see if any improvement happens. Thank you
dirk-s avatar image dirk-s gianluca commented ·
Csn you See that the battery is balancing? Meinst die lifestyle cell voltage goes Up with voltage abd the highest hieß down a litten bit? Is the Status in VRM or Console still "charging"?
gianluca avatar image gianluca dirk-s commented ·
Hi, I'm keeping batteries charged from remote console set the maximum charge current to 10 A, in 3 days i got the lower cell rising of 20 mV..
In VRM the status of battery is contimuosly bouncing from charging to idle and dischargin, loock like that when the highest cell reach the maximum voltage the system try to discharge to decrease the tension and then try to charge again maintaining this loop
Regards,
Gianluca
