byron123 avatar image
byron123 asked
Freedom Won E-Tower high discharge current alarm
Hi All
i am experiencing an issue whereby i get a high discharge current alarm whenever loadshedding begins. I have 4 x Freedom Won E-towers connected and running with a 15Kva quattro. Iv looked at the VRM logs and on one occasion 41A was being drawn and on another occasion the current being drawn is only 10A which seems too low to be getting an alarm? Also inconsistent? Anybody experience this with the E-towers? Any feedback would be greatly appreciated
Lithium Battery
nickdb avatar image
nickdb answered ·
Just search for etower, you will find numerous complaints related to its PACE BMS here.
Spikes can’t be seen on vrm easily but you will need to log a support ticket directly with FW.
Obviously check your setup is as per the joint ess document.
