What is the firmware number for the Mulitplus 11 48/5000?
I cannot find it on the Victron professional's text file.
Matt
Matt
Hi Matt. I think that .txt file you've found may be in need of an update too. Ignore it.
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
Under 'Notes' (#3), is the number you need to find. 26XXxxx.
Please read all the warnings before attempting this yourself. And I'm not even certain if that link is current.. take care..
Hi @Matthew,
Best is to check it with VEConfigure before you start, this way you prevent errors:
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
8 People are following this question.
