para756 avatar image
para756 asked
VRM-Logger does not calculate energy to battery correctly (BUG?)
Hi There! If got a problem and i narrowd it down to vrmlogger Service.
As you can see below, since the last days VMR-Logger service did not calculate the solar to battery energy. Everythin was counted as direct consumption.
#VRN-Logger Restart:
svc -d /service/vrmlogger && sleep 5 && svc -u /service/vrmlogger
#Systemcalc Restart (to be save):
svc -d /service/dbus-systemcalc-py && sleep 5 && svc -u /service/dbus-systemcalc-py
After a restart of vrmlogger, everything is calculated correctly. You can see the small blue line starting on May 6. It happened before from 20. to 22. of April.
There is VenusOS v2.94 installed on a Cerbo GX.
VRM
