I can't find the VRM portal ID to connect my device. I don't see the ID on my device or the box. I went to the settings in the latest version of the VictronEnergy app, but it doesn't show the portal ID.
Only GX devices have a VRM portal ID.
If you have a GX and VRM established, you need only connect the MPPT to the GX, and it will show on your VRM.
https://www.victronenergy.com/live/vrm_portal:getting_started
Is there another way I can connect my SmartSolar charge controller to the VictronConnect app? Do I have to buy a GX device for that connection?
Yep, I tried a different device today and it worked. Thank you again!
50 People are following this question.
