I noticed that it seems to use Impp instead of Isc when adding up the max Isc to check against controller allowable. Eg the 150/35 shown allows max Isc 40A but is showing as OK with 44A. If I change the Impp to 11A then it suggests a larger model.
31 People are following this question.
