allswell avatar image
allswell asked
How big of an MPPT do I need for 6 x 450w solar panels, 24v system?
I'm looking to add a second array to our home's 24v system. I'm buying 6 x 450w panels. What size MPPT controller do I need for this array? I'm not buying a Victron panel so I can't input the size of my panel into the MPPT calculator so I'm asking everyone instead. Please advise?
Solar Panelmppt calculator
ingo21 avatar image ingo21 commented ·
what are are you using in your first array?
6panel at 450watt is 2700watt / 24 volt is 112.5 AMP
you would need a mmpt charger capable of min 112.5 amps. that means big cables ...
or your run multible mppt controllers on different solarpanels with different settings for charging
Peter Buijs - NL avatar image
Peter Buijs - NL answered ·
@Allswell
Also in the online one.
