I'm playing with https://mppt.victronenergy.com and I'm confused because it somehow says
MPPT max. output current | 80 A |
for the SmartSolar MPPT RS 450/100. Why is that? I couldn't find the 80A anywhere in the data sheet.
One tracker can max. 80A. Add a 2nd tracker and you see 100A max. and 80A max. per tracker.
Okay, that's a bit weird since 4000W does not equal 80A, there's a voltage involved, too. But at least it sheds a light on why that number is there. Thanks.
82 People are following this question.
