droute avatar image
droute asked
Two Multiplus II in separate (parallel) offgrid Systems
Hi all,
how can this configuration be succesful?
Two Multiplus 3000; connectet to the same Battery bank; the first one is configured as an ESS System with connection over Ac-in to the house powernet. At the Ac-out there is a offgrid net with connection to the laundry and the cleaner.
Now there should be a second one with a separate offgrid net, to supply all cooling systems.
How can the second one be connected to the cerbo?
How can the second Multiplus 3000 be configured?
Thanks for help
multiplus in parallel
