fordens avatar image
fordens asked
High output alternator connection to Lynx BMS 500
Hi all,
Planning to install a whole new solar/alternator/wind system on my canal boat, just try to understand how can I connect a high output alternator to my setup.
The idea is to get a controlled Belmar 260ah and use the output to the maximum possible in order to have to run the engine the less possible.
Can I connect the alternator directly to the Lynx Distributor side (supposing that the Lynx BMS 500 will control and manage the charge current) or I miss something in between? I want to avoid to install 5-6 Orion’s just to get the same amperage as an alternator.
thanks in advance
alternator
mvas avatar image
mvas answered ·
There are several threads discussing the Victron BMS + Balmar + Lynx. Don't forget about the contactor inside the BMS. Have you selected how the BMS will "communicate" with your regulator?
pwfarnell avatar image
pwfarnell answered ·
What regulator are you planning on for the alternator, the Lynx BMS will communicate charging to a Wakespeed WS500 through the Cerbo GX but I do not think that it works seamlessly with Balmar regulators.
