I have the following setup
- Cerbo GX (FW 2.94) - connected via supplied cable as well as trying pin to pin RJ45 cable.
The Cerbo GX is powered via the battery (52.45V) measured .
What am I missing?
Ken
@kejba@outlook.com did you get your issue resolved? I'm having the similar issue https://community.victronenergy.com/questions/217979/cannot-see-blue-nova-batteries-on-cerbo-gx-device.html
Yes I solved my problem.
As per the Blue Nova manual you should only connect pins 7 and 8 on the BMS cable (RJ45 connector) between the Cerbo and Blue Nova Racpower.
I simply ripped apart a standard RJ45 cable and cut off all the wires going to unused pins - worked perfectly thereafter.
56 People are following this question.
