After 7 months without any trouble my Absorbtion Voltage has
risen up to 17v and then dropped down again. I have the battery sense fitted but it worked fine before. I was told to turn off the networking but it is still having the same problem.
is there anything else connected that can charge the batteries.
when its showing 18v this is at the solar reg terminals. whats the voltage at the battery.
the battery sense is measuring the voltage at the battery, removing it or disconnecting it changes the setting back to the regulator terminals.
some screen shots are from the battery monitor, and the others from the regulator, what is the battery monitor showing at the same time as the solar reg
45 People are following this question.
