b380 avatar image
b380 asked
Isolating Generator Battery - Orion?
I have an auto start SOC setup for my 5th wheel generator using my CerboGX. The problem is that when the generator kicks on it of course draws a lot of amperage, causing a significant power drop to things like my referigerator, computers, etc. What I want to do is isolate/dedicate a cheap AGM battery to the generator only.
Am I correct in my research that the Orion is going to be the best bet for this? Do you have any other recommendations?
Generatorgenerator auto startorionstarting generator
kevgermany avatar image
kevgermany answered ·
Electric start generators usually have their own battery and built in charging for it. If it is used regularly, no need for a charger. But yes, on the Victron range, if you want to charge from DC, the Orions are what's needed. If you're thinking of charging from AC, the Phoenix chargers are what you need.
