hallohieristjan avatar image
hallohieristjan asked
Cannot connect to SmarSolar 75/10 after failed firmware upgrade
after connecting to my SmartSolar 75/10 with VictronConnect via Bluetooth for the first time, a firmware upgrade was triggered. The upgrade failed (there was a message saying that the device didn't install a new bootloader, but that installing a new bootloader was expected, or something similar). When I try to connect again, there is a status bar raising until 60%, then back to 1%, then up until 60% again, and then there is an error message saying that the connection has failed and suggesting that I move my mobile closer to the SmartSolar. Shortly before it falls back to 1%, all three LEDs flash a few times.
I suspect that the connection issues are due to the failed firmware upgrade. Is there any chance I can fix the connectivity?
VictronConnectsmart solar set-up help
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @hallohieristjan
Please remove the device in the bluetooth menu of the phone/tablet. This is described here: https://ve3.nl/VictronConnect_Bluetooth%20Smart-Removing-from-the-list-of-paired-devices
After this, you should be able to connect again and finish the firmware upgrade.
Kind regards,
Thiemo van Engelen
hallohieristjan avatar image hallohieristjan commented ·
This works, thank you!
VictronConnect Manual
Download for iOS / Android / Mac / Windows
