faure avatar image
faure asked
More details on the ground relay
Greetings Victron Community
Can someone provide more details on the internal ground relay itself. Are there any specifications and/or standards the relay is adhering to and what other safety features are included to ensure the ground relay is always in a working condition and that the neutral earth bridge is properly established.
Thank you in advance
RelayGrounding
Trevor Bird avatar image
Trevor Bird answered ·
@Faure When in inverter mode, If you check voltage on output between neutral and earth and it is zero, the ground relay is working.
5 comments
faure avatar image faure commented ·
Dear Trevor, thank you and noted. I however would like to know what specifications and/or standard does that relay and the working of that relay adhere to as this is a critical safety feature for networks with TN-S earthing arrangements. I expect this relay not to be a standard of the shelve relay, hence the request for more technical details. Would you be able to assist?
Trevor Bird avatar image Trevor Bird faure commented ·
@Faure sorry I dont have the details of the exact relay.
Alexandra avatar image Alexandra ♦ Trevor Bird commented ·
The simplest way is to open the unit, look at the relay and look it up online.....
nickdb avatar image nickdb ♦ faure commented ·
If you search for ground relay errors on the victron site you will find a lot of information.
faure avatar image faure nickdb ♦ commented ·
Thank you Nick, I did find that information and that was helpful. The other posts did not provide clarity on specifications and/or standards the relay and the monitoring that goes with it adheres to. Really hope someone would be able to assist.
