adev avatar image
adev asked
MiniBMS compatible with older (non-smart) Lithium batteries?
I’ve just bought (not yet collected) two secondhand, older Vitcron 60ah Lithium batteries. I will charging them with a MPPT 100 | 20 and running only DC loads via the load output on that controller.
My question is, are these older batteries compatible with the MiniBMS? I tried to find the spec sheet for them but I can onlt find that for the newer smart batteries.
Lithium Battery
Paul B avatar image
Paul B answered ·
as long as they have the same cable conections as on the minibms then yes they are compatable
5 comments
adev avatar image adev commented ·
Thanks Paul. As far as I can tell they do... (can just about see the connectors between the centre of that fluke meter). The seller has not been very responsive to my questions and I won’t collect until next weekend.
Paul B avatar image Paul B adev commented ·
Yes they look the same
A MiniBMS or a VE-BMS will both work
I like the VE-BMS if you have a multiplus as it turns the charge or the loads off on the inverter without any other relays and then you can control the external loads with a smaller relay and or a charge relay as well.
but if you dont have a Multiplus or a Quattro then a mnibms would be the way to go
adev avatar image adev Paul B commented ·
Thanks. I don’t have any other victron equipment. As far as I understand I can use either of those BMS to send a signal to the MPPT to switch off the load. I may ad a battery monitor at some point - in which case would it be better to have the VE.Bus BMS? ie. is there any advantage to that?
No only if at some point you may add a Multiplus or Quattro Inverter/charger.
otherwise stay with the minibms
ok great, thanks :)
