What is the peak reverse voltage for the Argo Diode Battery Combiner BCD 802 ?
what are the diode model inside ?
@Steve777 I dont know the type of diode used and I doubt victron would simply provide the information so folks can build their own but if I were to build one I would use a MBR8080 80 amp schottkey diode that has an 80 volt reverse voltage rating. That way it could be used for 48 volt systems if required. That mounting style is also easy to mount to a heatsink so manufacture is pretty simple.
37 People are following this question.
