the battery voltage was displayed in voltage and then it started displaying in percentage. I read one answer that said it was a “bug” in VRM?
Make sure you have "Show details" clicked. That should bring back both, voltage and SoC in percentage.
I have “show details “ turned on.
I’m not seeing my “House ESS” and I’m not using ESS. I’m looking at my installation dashboard, historical data, system overview, consumption/solar/battery graph.I’m seeing details and the graph is showing voltage as percentage not actual voltage. It was showing actual voltage and now it is maxed out at 100%. I could have changed something unintentionally, I’m new and learning.
I emailed the screenshot to bounces@victronenergy.com because I couldn’t figure out how to post it, “invalid image“? I still haven’t solved my issue.
On my VRM dashboard under,
Historical data, system overview, consumption/ solar/battery graph. The battery voltage is displayed as percentage instead of actual voltage value? It use to display the actual voltage, something (maybe me?) changed it to percentage. How can I correct that?
50 People are following this question.
