wongamatt avatar image
wongamatt asked
How do I turn solar “on” with easysolar 48/5000
hi, recently installed an easysolar-IIgs 48/5000. upon installation all is working correctly howerver i cant get the solar mppt to "turn on" using the dashboard it seems like the only option that doesnt let tou enter or change relay state? kind regards
dashboard display
kevgermany avatar image
kevgermany answered ·
It's always on. If there's sufficient solar input it starts charging.
If you use Victron connect to connect to the MPPT, you'll have access to the settings.
Probably a good idea for you to check out DVCC and enable that on the GX.
8 comments
wongamatt avatar image wongamatt commented ·
The one line LCD display literally says “solar off” and likewise it is reflected as off in the remote console with no option to turn it on that I can find. DVCC is however off, I’ll start with that. Thanks for the input
nickdb avatar image nickdb ♦♦ wongamatt commented ·
It will be in an off state if minimum PV voltage isn’t ~6V above the required battery charge level. What are your panel voc specs and configuration?
wongamatt avatar image wongamatt nickdb ♦♦ commented ·
I have a second MOPT charge controller 250/100 and it works fine with same leads connected. It’s displaying a message “disabled by remote or BMS” in the app.
kevgermany avatar image kevgermany ♦♦ wongamatt commented ·
Which batteries/BMS?
wongamatt avatar image wongamatt kevgermany ♦♦ commented ·
Nothing to do with the batteries as the second charger (not within an easysolar rig) works as intended with the same batteries and wires!
klim8skeptic avatar image klim8skeptic ♦ wongamatt commented ·
that is important info to know.
do you have its remote port jumper in?
wongamatt avatar image wongamatt klim8skeptic ♦ commented ·
It’s a stack of agm 6 volt cells. Remote wire from the easy solar is connected to the H terminal. If I can’t find a solution I’ll put a jumper in?
@wongamatt the mppt in the easy solar is the 1 that does not charge?
Check this post and be very careful. Disconnect ac and batteries before removing any covers.
gerard-van-seventer avatar image
gerard-van-seventer answered ·
Some of the solar chargers inside the EasySolar are incorrectly wired. See this
Maybe yours has the same. It's an easy fix.
wongamatt answered ·
Yes this was my first thought after navigating the online dashboard thing for a few hours… google says the wire should be in the H terminal, and I confirmed it’s there. Out of curiosity can I brute fires this and out the jumper in line a non remote controlled model?
