wade avatar image
wade asked
Charge controller display
Good morning,
I’m unable to find if there is one available but I’ve recently purchased a SmartSolar charge controller 100/30 MPPT and am looking for a display/control panel to attach to the unit, I did find one but it stated it was compatible with the 100/50 controller, do you stock a product that is compatible with the 100/30??
Cheers
Wade
MPPT Controllersdashboard display
Your text is white on a white background.
The smaller MPPTs don't have a connection for the display you found.
For your 100/30 you can use this one:
https://www.victronenergy.com/panel-systems-remote-monitoring/mppt-control
but you also need a VE.direct cable:
https://www.victronenergy.com/cables/ve.direct.cable
and maybe the Wall mount enclosure
https://www.victronenergy.com/accessories/wall-mount-enclosure-bmv-or-mppt-control
