thomashofbauer avatar image
thomashofbauer asked
EV Charging Station IP Adresse
Hallo bei meiner Anlage ändert sich die IP Adresse, die Ladestation hängt über einen Reichweitenverlänger (über die Steckdose am W-Lan) und der Cerbo über einen anderen Reichweitenverlänger a, WLan. Jetzt erkennt die Ladestation den Batteriestand des Speichers nicht mehr und die Ladung funktioniert nicht mehr. Was muss ich tun das sich die IP sich nicht verändert bzw. das der Cerbo die Ladestation wieder erkennt. Die Dinge in der Anleitung habe ich denke ich alle schon versucht.
Danke für die Tipps Thomas
ev charging station
Lucian Popescu (Victron Energy Staff) avatar image
Lucian Popescu (Victron Energy Staff) answered ·
Hi, we are preparing a new firmware (1.25) that is not using the IP address to pair with the Cerbo, it is using the ID of the device. So even if the IP of the Cerbo is changing, it will still work.
Keep an eye on the updates, today, or tomorrow should be release. Lots of new features are included.
Released, please update your unit and share your feedback
thomashofbauer avatar image thomashofbauer commented ·
Thank you i will wait for the update
thomashofbauer answered ·
Hi, i want update the ev Chager if i i do this with the new software EVCS_Main_FW_OTA_V01.25_C026.evcsup it is not possible. The Update with the file EVCS_Main_FW_OTA_V01.25_C025.evcsup is possible. Is the file C025 the right one?
And i have no GX communication: see picture below "GX communication error:Minimum SOC can't be checked"
what can i do?
thank you very much
C25 is the screen version
C26 is the version without screen
Do you have a GX device in there? Or you are using the charging station stand-alone?
thomashofbauer avatar image thomashofbauer Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
Hi Lucian,
i have a GX Device > charging in the Manual Modus is possible
Mod Bus is on
this are the ip Adresses
ican see the device in the VRM
setup VRM
thanks for helping Thomas
I think on the GX side, modbus tcp is not enabled. Go to settings/services and check it
5 comments
is this ok?
Hi Lucian, have you an other Tipp for me?
thanks
Lucian Popescu (Victron Energy Staff) avatar image Lucian Popescu (Victron Energy Staff) ♦♦ thomashofbauer commented ·
So it's still not working? Are both devices on the same Wi-Fi network?
No it dont works. its the same network in the house but 1 have a network range extender > one for the cerbo and one for the EV Charger
That might be the issue, can you try connecting both devices on the same Wi-Fi, maybe create a hotspot with your phone and try like that?
