Gerrie Rossouw avatar image
Gerrie Rossouw asked
ET340 and PV inverter on Victron output
Good day,
I have been trying to find the correct diagram with no avail,
I have a 45KVA Victron 3 phase system and a ABB Trio 27Kva on the output side,
The ABB has no communication to the Victron Cerbo, therefore i need to install an ET meter to see the PV production,
How would i wire the meter if it is 3 phase and i have the PV inverter on the output side,
Any info would be much appreciated,
Regards
Energy MeterAC PV Coupling
rnauschnegg avatar image
rnauschnegg answered ·
Why you are not doing like that: https://www.victronenergy.com/live/ccgx:abb_fimer?s[]=abb&s[]=inverter
Gerrie Rossouw avatar image Gerrie Rossouw commented ·
This is a 27 Trio, which has no communication with Victron, i have tried, spoken to ABB as well.
Only the Trio 50 and 60 works
rnauschnegg avatar image rnauschnegg Gerrie Rossouw commented ·
Ok, so just install the ET340 between the ABB and the Victron AC-out. ABB hast to be connected to L1 L2 L3 IN of ET340.
