palpil avatar image
palpil asked
After reboot Cerbox GX - Ethernet Reconnetion issue Version 2.93
If I reboot my Cerbo GX, then the connected LAN Ethernet is not working again.
If I ping the IP Address of the Cerbo, the device is not answering.
I need one times unplug the Ethernet cable and plug again. Then it is working normal.
Is this a defect?
Thanks.
palpil
cerbo gxethernet
nickdb avatar image
nickdb answered ·
Have you made sure wifi is disabled?
Try another cable and check the port settings on the switch, it should just come online after a reboot.
If you leave it for a few minutes does it recover by itself?
JohnC avatar image
JohnC answered ·
Hi @palpil
This may not be a 'defect', but there's a quirk in there somewhere.
I use both ethernet and wifi. Whenever I reboot the GX I first set them both to Automatic in the GX. After the reboot and they've received an address, I change them to Manual. Then they roll on happily. Don't ask me why, but works for me.
