groningen avatar image
groningen asked
Ve Smart Network vs Ve Direct cable
Dear All
I have read some of the older Q&A regarding VE Smart Network vs VE.Direct, but I would like to know more details.
My Shunt and MPPTs (without Bluetooth) are connected to the Cerbo and all is working perfectly together with my Multi ii (VE.Bus).
Checking some of the YouTube video's, some indicates that if you set up the VE Smart Network, all other MPPT's will follow (I assume especially when DVCC is activated).
My question : I prefer hard wire to connect all, but is there any additional advantages when going via Bluetooth (emphasis on VE Smart direct) versus the old fashion way of VE.Direct?
Some have pointed out that you cannot have VE Smart and VE.DIRECT together (not sure if this is still the case) as they do not "talk" to each other (from old posts).
Maybe also a consideration for me, I should get a VE.Direct extender (Via USB) for more ports if this will be in my favour.
Any advise or tricks will be helpful.
VE.DirectVE.Smart Network
nickdb avatar image
nickdb answered ·
Smart networking is meant for smaller installs without a GX. It is not recommended to have it running together with a vedirect connected system as some have experienced conflicts.
The current docs state as much.
groningen answered ·
@nickdb Thank you for the quick response.
VE.Direct protocol FAQ
VE.Smart Networking Manual
