path avatar image
path asked
Generator connection to cerbo
We want to connect relay 1 on the Cerbo to start and stop our generator automatically whenever the system decides that the battery bank voltage is too low and the solar panels are not providing enough input on a cloudy day and it needs to charge the batteries.
We also want to have 1 wire for keeping the generator battery charged.
The generator auto start has 1 positive connection, 1 negative connection and 1 for keeping the battery charged.
Can all this be done through relay 1 and if so which wire do we connect where ?
josch avatar image
josch answered ·
Hello, I switch my inverter with relay 1. He works up to 20%soc and then switches off. at 35% soc he switches on again. Relay1 OFF -> Connection left and centre are switched through. Relay1 ON -> Connection Right and centre are switched throug
