dragonfreak avatar image
dragonfreak asked
Battery Modbus Data
Hello
I connected a battery with Pace BMS to a CerboGX via CAN Bus.
Its working, i get data from the BMS displayed in the Cerbo.
Now i tried to read those through Modbus in ioBroker like other Sources (MP2, Gridmeter), but i get the following error:
Error processing function Code 4, Unit id 225, start adress 13, quantity 2, src 192.168.178.85: Error finding service with device type vebus at device instance 512
Any ideas?
Greetings
Christian
Modbus TCP
matt1309 avatar image
matt1309 answered ·
Hi @dragonfreak
The error code seems to suggest that you're trying to get address 13 on Unit 225.
When I look at modbus TCP registers I can see address 13 is Input power 2 (as in L2 on ACIN). I might be misunderstanding but i think the address might just be incorrect?
tnt369 avatar image
tnt369 answered ·
Battery (Unit ID 225) only support adress range 259 ... 326!
gamechanger avatar image
gamechanger answered ·
Hello Christian,
which cable did you use to connect to Cebro?
I'm also stuck on a Pace BMS.
What setting did you choose here?2023-04-26-13-17-13-pbmstools-hs107-protocol-code.png
Thanks
Klaus
