louis becht avatar image
louis becht asked
battery is not listed as compatible ?
New here new to solar, extremely qualified electrician, I have 4 Eco-worthy 12v 100ah LiFePO4 battery's, Victron MultiPlus II 12/3000/120-50 2x120V inverter this battery is not listed as compatible ? is why and can or how do i set inverter to accept them.
charge controller compatibility
Alexandra avatar image
Alexandra answered ·
@labecht
See the manufacturer recommended charge and float voltages as well as charge amps.
Set the inverter accordingly.
ejrossouw avatar image
ejrossouw answered ·
@labecht LifePO4 batteries, more so 48v models, can be connected to inverters and share information that can be used by the system in various ways. The listed models were tested to work with Victron equipment and is "supported" by Victron. This does not mean you cannot use other batteries, just that they will be set up / used as you will e.g. AGM without intelligent features in the system.
nickdb avatar image nickdb ♦ commented ·
It is worth adding that many unlisted batteries are compatible with Victron CAN messaging, just that it is up to the battery manufacturer to support you if it behaves unreliably.
