Hi
Is the SmartSolar MPPT 100/30 able to deal with a LiFePo 24V/200Ah battery pack ?
Battery Pack has integrated BMS 8S 200A (also RS485/CAN)
Plan to connect 2 x 395Wp (44.7V) PV panels in series connection.
appreciate feedback
best regards,
Hi
appreciate feedback
best regards,
By deal with i assume you mean charge?
At 90% DOD charging at 30A will take close to 7 hours. So if you are planning on that kind of use, get more solar.
The series connect, check your max VOC at min temps with the online calculator and other details for your panels.
Hi Alexandra
yes, question was regarding charge of LiFePo batteries. For the setup mentioned above, i need more panels, agree ;-)
With exactly that panels i was able to catch 3.6kWh today, which is to less for 24v/200Ah.
Also noticed that SmartSolar MPPT 100/30 does not have a "Load" output compared to MPPT 100/20.
Is there an alternative way of connecting and switching a Relay to MPPT 100/30 ?
According to the MPPT Calculator I'm fine with 2 panels in series connection up to 375Wp/Panel.
For higher Output panels it recommends MPPT 100/30.
49 People are following this question.
