roger-1 avatar image
roger-1 asked
Solar edge output not correctly reported in VRM
Cerbo Gx displays correct kW output from SolarEdge Se6000. But only a fraction of this is reported in the VRM data. So when I have actually generated, say 6kWh during the day VRM is reporting 0.2kWh.
All firmware upto current date
CerboGX. V2.93
Smart Shunt 500A. V4.13
Multiplus 2 48/5000/70-48. V502
solaredge
suggarman avatar image
suggarman answered ·
Do you have any other device connected to the solaredge? Solaredge can only handle one device. If data is needed, you have to get it from the cerbo.
Integrating with SolarEdge
