fox1980 avatar image
fox1980 asked
ESS charging
Hi I have an ESS system in operation as above, my issue is why am I exporting over 1kw and only charging at 64w?
I have the 48v multiplus with 200ah of Gel batteries.
It is set to optimised with battery life and self consumption.
Thanks in advance
Dave
battery charging
hominidae avatar image
hominidae answered ·
...what's the target voltage in DVCC settings for your pack and the settings for the batteries in ESS assistant...do these match your batteries?...with SoC already quite high and voltage of 58.26V in cold weather, the system may be close to fully charged already.
Galin Radoslavov avatar image
Galin Radoslavov answered ·
May be charge efficiency value is not correct - every battery have different value - try 0.85
fox1980 answered ·
Hi, the DVCC option in the menu is switched off, with a message saying read manual before adjusting.
fox1980 answered ·
I know the basics, can you tell me how and where to change these values please?
Thank you
