duncangardiner avatar image
duncangardiner asked
Maximum input Amps each solar channel of the MPPT RS 450/100 can handle
I have a question re the MPPT RS 450/100 charge controller. What is the Maximum input Amps each array of solar panels can pass into each channel on the charge controller? The documentation is not clear. From a data sheet I found it looks like the max amps should be 18A, but that is not clear if that is the total for both channels or for each channel, or some other number.
I am trying to confirm that each channel on the MPPT charge controller can accept 10 solar panels that are 540Watts with a max output of 41.64V at 12.97A each. My math looks like this, 10 panels in series should equate to 41.64V x 10 = 416.40V at 12.97A, which means I should be able to have 2 arrays of 10 panels, one into each side of the MPPT RS 450/100?
Thanks Duncan
charge controller compatibility
Jons Collasius avatar image
Jons Collasius answered ·
Max. PV operational input current 18 A per tracker
Max. PV short circuit current (2) 20 A per tracker
https://www.victronenergy.com/solar-charge-controllers/smartsolar-mppt-rs-450-tr#datasheet
duncangardiner avatar image duncangardiner commented ·
Thanks for the confirmation. so my math seems to be fine based on this document.
JohnC avatar image
JohnC answered ·
Hi @Duncan.Gardiner
Run your figures through this.. mppt.victronenergy.com/
But please don't use Vmp for the voltage, use Voc plus Temp Compensation. Maybe you'll get 8 panels in each of the 2 strings.
This calculator deos not cover panels of my size nor the MPPT RS 450/100
nickdb avatar image nickdb ♦ duncangardiner commented ·
If you select "custom module" you can enter any panel specs.
Add multiple trackers and the calculator happily suggests the RS450 models
Alexandra avatar image
Alexandra answered ·
@Jons Collasius
Maximum amps is 30A. But the caveat is anything above the short circuit rating of 20A already mentioned by others is not covered by warranty when a mistake is made.
https://www.victronenergy.com/media/pg/SmartSolar_MPPT_RS/en/installation.html#UUID-a96ec91b-a21c-0536-1a40-278fd7f9410d
