sneruh avatar image
sneruh asked
Using a Multiplus to charge a battery
I have a 24V 2000 Multiplus (120V version and not the Compact) with two 12V100Ah LifePO4 batteries in series. I have an AGM battery that I use elsewhere that requires charging at 14.7 volt. I was wondering if could charge my 12 V AGM battery with the Multiplus in Charge only mode? This would require me to temporarily disconnect my two 12V LifePO4 batteries connected in series. Is this possible?
battery charging
klim8skeptic avatar image
klim8skeptic answered ·
@Sneruh You can not charge your 12v AGM from your 24v Multiplus.
Do you have a 120v / 12v battery charger?
sneruh avatar image sneruh commented ·
Thanks. Yes, I do. But I was thinking that with the Multiplus I can adjust charging characteristics, i.e. charge at 14.7 instead of 14.4. Turns out that my external charger, NoCO Genius 5, does charge at 14.8. That's what I will have to use.
