Hi!
I have succesfully installed Shelly EM from https://github.com/vincegod/dbus-shelly-em-smartmeter and with 2 lines changed I managed to see it in interface but not under Energy Meters.
Anyone had better luck?
Hi!
Here are some captions:
I have exactly the same issue, the shelly appears in the device list and updates correctly, but it does not show in Energy Meters, nor does it have the option to set a role in the device itself. I therefore don't believe I can use it with the grid metering in ESS. Has anybody had success with using a shelly (connected on the d-bus) as a energy meter and used in ESS?
I use it in ESS and it works fine
As far as I know only RS485 meters directly connected to the MP will be shown as Energy Meters.
93 People are following this question.
